Is it an old sim from a previous phone or a new one?
Your APN's may be correct, but there could be something wrong with the actual network settings themselves.
If you go Settings -> Wireless & Networks -> Mobile Network Settings -> Network operators does the small text underneath that correspond with your home network? Orange/T-Mobile/O2/Vodafone (obviously these will differ if you're not in the UK) etc? Tap "Network Operators" and then "Select Automatically".
I had the same problem since today morning. I wasn't able to make calls though my emails were getting delivered. Full Network. I had tried restarting several times and removing the sim / sd card.
Although selecting "Select Automatically" did not work for me, I went through the same menu given in earlier post and forcibly selected my operator (Airtel India). This solved the problem. Thanks.
