Help HTC Desire HD internet problem
Do you get any error messages, or is do you just get standard "Page cannot be displayed" errors etc?
You could try assigning yourself a static IP, that's known to have helped. Have you also tried changing the wireless channel on the router?
Yes, it says that the page cannot be displayed.
Tried both, setting a static ip and changing the router wireless channel and still nothing.
Any other ideas?:confused:
I bought the phone a few days ago so the version was already that one and my router is a barricade smcwbr14s-n2.
Thank you for helping me out
No problem!
There have been compatability issues between certain routers and the DHD (Although I think it's an Android problem in general) and the symptoms are exactly the same as you are experiencing. When you tried assigning a static IP, was it on the phone or the router itself? If it was the router, try setting an IP on the phone, see if that makes a difference. If not, it might just be the router/phone combo isn't compatible. Do you have another router you can try?
If you need info on assigning an IP on the phone, check here: http://androidforums.com/desire-hd-...45055-desire-hd-wifi-problem.html#post2755542
Well, i think its a router problem.
I managed to connect to the mall wifi and it worked, i was able to access any internet related application.
