Hello,
I finally decided to bite the bullet today and root my phone. The main reason is because its a orange branded phone and I want to get rid of all those horrible apps they pre-install for you.
I have been following this guide on your forums:
http://androidforums.com/desire-all...ff-root-htc-desire-revolutionary-updated.html
I created a gold card before I did anything else
I used the revolutionary method. I was lazy and let their program do everything e.g. install the default recovery file it supplies.
Everything seemed fine. I managed to get S-OFF and install zip file from SD. Superuser zip file seem to install with no errors. However when I check to see if my phone is rooted it says it is not and has no superuser app.
I checked to see if my phone was rooted with root checker and titanium backup.
My HTC Desire info is below:
Model Number:
HTC Desire A8181
Android version:
2.2
Baseband version
32.48.00.32U_5.10.05.30
Kernel Version
2.6.32.15-g29e526b
htc-kernel@and18-2 #1
Build No.
2.17.61.3 CL274424 release-keys
Software Number
2.17.61.3
Browser version
WebKit 3.1
Here is a image of my Hboot. You can see that S-OFF successfully.
http://imageshack.us/photo/my-images/28/img1681il.jpg
Any help would be appreciated
Model Number:
HTC Desire A8181
Android version:
2.2
Baseband version
Kernel Version
2.6.32.15-g29e526b
Build No.
Software Number
2.17.61.3
Browser version
WebKit 3.1
