Help HTC Desire S music problem
Hello all,
I have just bought a Desire S. Its a good phone and Android simply rocks. The only problem I'm facing is that when I use the stock misuc player with the stock HTC earphones, it skips bits of the songs and there's static which gets irritating.:mad:
I thought it might be due to faulty earphones. So I tried using my iPod nano ones but its giving the same problem with that too.
As mentioned on one of the posts, I have also tried installing the "Block Headset" widget, but to no avail.
Can someone please help with it?
Thanks in advance...
For any one else who has a similar problem, the simple solution to the problem which I found after 2 hectic head-racking days of trying various solutions is to enable Pattern Lock for your screen from Settings > Security...
This worked like magic for me....
I tried this, yet I still have this problem. HTC say they have no idea what I'm talking about when I e-mailed them about it.
EDIT: I think I have fixed it! I removed the memory card, blew in the socket, wiped the card, then inserted it again. It seems to have fixed it!
I need your help regarding the purchase of desire S. I came to know about some gap in front Lcd glass and loose battery cover. what do you guys say?
