Help Htc desire usb is not properly detecting
everfor
i tried in multiple laptops of windows 7, my htc desire 2.1 usb sometimes doesn't detect at all. its totally weird, out of 10 times try, its work for one time. Sometimes its auto disconnect, in mid of file transfer.
Even i tried to installed android usb drivers, but no use. Any solution for this.
I've had issues with this with cheap USB cables. I only use the HTC supplied or branded cables sourced from a reputable supplier now.
if its charging ok, the cable's probably ok - are you selecting disk drive from the notifications bar? Are you doing anything on the phone when it disconnects?
