htc evo issues
Lately on my phone i have had this message pop up saying "Data Call Failure: Error Code 67 Registration failure." And it pops up literally every 30 seconds and will not go away, I also can not get on the internet at all anymore cause it says it cannot fetch data. Does anybody know how to fix this? And also I am not receiving texts hours later.
I tried that yesterday and it didnt work, but I will try again. And i also get messages that say "SMS Error, Radio Interface Resource Shortage."
Yeah, that "SMS Error, Radio Interface Resource Shortage." seems like something has gone haywire at the system software or hardware level.
If nothing else works, you might try a hard reset.
I had same exact error code - easy to fix: called sprint rep, she had me turn off phone, remove battery, while she did something that would refresh my account info to the phone. then had me turn on the phone, and it fixed itself.
so try the battery pull, and if that doesn't work, call sprint and they will do the account refresh thing and tell you to do the battery pull
I was getting that data call failure after trying to use the moblie hot spot app. Im guessing because I do not pay extra for it that this is how it tells me I cant use it. After going into the hot spot setting and turning it off the error went away "I think closing the app still keeps it running". Did you or anyone turn on the mobile hot spot app? Worth checking into.
I get that occasionally when I am sending a text and another one is coming in at the same time then I have to long press the text I was trying to send and select retry sending. But I would call sprint immediately and just let them walk through a few things... Probably need to be reprovisioned
