HTC Hero txt message problem...
My sprint HTC hero for some reason will all the sudden stop allowing me to get txt messages and mine that i send dont seem to reach the phone im sending it to. It will stop working out of the blue and start back up. The only reason i know that it stops is because the person i am txting shows me that they never received a message from me and i never got one from them. My phone does not tell me i cant receive or send it just stops and i never know. When it starts working again it does not ever send the messages i didn't receive. Is anyone familiar with this issue?
Are you using the stock messaging app? I know there is a failure notification setting in this so if your messages don't get sent it should tell you, otherwise, I'd say the problem is on the other persons end.
Well try using the stock app for a bit, if your sending fails you will get a notification saying so.
Handcent also has a notification for sent message failures
Is your internal memory low? Because that can cause you to stop receiving texts/voicemails
If you're only using handcent for individualized notifications, try sms popup. It works great and has yet to cause me a problem
