Help HTC Incredible Boot Animation Help.
Kushie
Okay, So I've done everything right, following Big Lou's tut. It all happened to go down smooth, then when I pushed the bootanimation.zip into my phone, it added it, but my boot animation is still the same stock one. Anyone please help.
What rom are you running? Also make sure you are putting the zip where the current one is so that it overwrites it. I believe most are in system/media
go through ur files and where you see a BOOTANIMATION.ZIP file, replace that with the bootanimation you want. its real simple.
