FrustratedHelpMe
Hi,
I just got an HTC Incredible (original model) that I bought from a dealer on Amazon to activate on Straight Talk. Well, I don't know what exactly happened. I had completed the transferring of my phone number, and as I was waiting for the port to complete, I went ahead and connected to the WiFi in my house and downloaded my apps. I inserted my old microSD card and started listening to some music I had stored on it. Everything seemed to be working fine. Then I made the call to start programming the phone. The call disconnected and somehow I got stuck on the HTC boot screen. I may have pressed a button somewhere in the confusion, but I'm not sure?
Anyway, here I am. The phone is stuck at the "HTC Incredible" TM white screen. It pops up like it's going to boot up, goes black for a second like I should being seeing the red Droid eye, but instead it just loops over and over with the HTC Incredible screen.
I've tried:
-Pulling and replacing the battery
-Rebooting from the reboot screen
-Selecting recovery from the reboot screen
-Selecting Factory Reset from the reboot screen
I can't get any further than the reboot screen. I can select options from the menu as above, but when I select one all that happens is the "HTC Incredible" white screen loop starts over again. It won't do anything else.
Can someone please help me? I've tried reading the threads with similar issues, but I haven't found one with this exact issue. And also, I don't speak techie, so if you could help me troubleshoot in layman's terms, I'd be very, very, very grateful.
Thank you!
I've tried:
Thank you!
