Help HTC Nexus One will not boot past X
Taiidan
Hello there,
I will start by saying that I have no knowledge of Android software or the processes behind them. So I have come here to resolve a problem with a phone that I have been given to use while my windows mobile is off being fixed:
I have been given the HTC Google Nexus One phone which boots up to the X logo and goes no further. I believe the battery drained down to 0% and have been told this is the result of the loss of power and have been suggested to do a recovery on the phone. I do not have any software for this phone or the know how to doing this.
Thank you in advance.
This procedure will erase everything on the phone:
-Turn the power off. If your Nexus One is frozen, pull the battery out and reinsert it
-Hold the Volume Down button
-Press and release the Power button
-You are now presented with a menu that allows for Fastbook, Recovery, Clear Storage, and Simlock
-Select Clear Storage by pressing the Volume Down button
-Now simply confirm your decision: Volume Up for YES and Volume Down for NO
Thanks for the quick reply, I have just done what you have suggested and it had rebooted after 5 seconds, the X logo unfortunately still persists.
The X logo is a still image with a black background, no animation with lines rushing towards it so I do not believe it has been manipulated in any way. It should be as it was purchased.
Mine is doing the exact same thing. No animation just the 4 color x with black screen. I tried clearing all user data, fast boot and all other options in the recovery screen to no avail. Is there a way to recover this or shall I give it to the puppy and 1 yr old to play with?
