... not recording the date and time in the EXIF metadata.
I don't want you to think that your question is ignored, but personally I haven't even looked into that on my phone. The best answer I can give is "I don't know".
Have you tried running the RUU? Or rooting and using a different sense based ROM? Not sure that either will solve your problem, but they might.
I don't have this issue so I can't check anything out, but there are some free camera apps that will print the date and time on the photo, if this is a possible solution for you. But, I don't know if they need the EXIF metadata to be there to work.
Might be worth trying them out to see if they will put the date and time in to the EXIF metadata, then at least you will know if the problem is with the phone or the camera app.
Couple of links below to two camera apps that print the date and time on the photo
eCamera
Camera 360
Hope one of them helps
Mine records the date and time correctly (I just checkedCan anyone with an HTC One S verify if their phone is recording the time and date in the file itself?
).A RUU is a file you run on your computer with your phone connected that basically restores the phone software to factory conditions. A factory reset will not replace missing files/apps, a RUU will take care of everything.I'm not familiar at all with "RUU" or "rooting and using a different sense based ROM". What is that?
Mine records the date and time correctly (I just checked).
Rooting and installing a ROM are even more advanced tasks than that. Rooting gives you superuser access (think administrator access) on your phone, and ROM is a custom OS.
If you are not familiar with this stuff, then I wouldn't recommend trying to do either to solve your issue.
In fact it may be worth seeing if you can get your phone replaced, because it should be recording that data correctly.
I've just taken a photo and mine records everything correctly on my One S. Checked about a dozen random photos and they are all recorded correctly
If you delete/modify certain things a factory reset won't restore them, running the RUU will. Like if a system app is deleted.How does an RUU replace missing files/apps if it's restoring the phone to factory conditions?
I checked on my windows 7 PC.Thanks to both of you for checking but I have another question. Are you checking the time and date for the file on the phone or through Windows OS on a computer? One quirky thing I've noticed is the date and time information seems to be displayed when viewing the pic through the the phone and accessing the "details". But when viewing the file/pic through any other means like Windows there is no time and date data there.
