Root HTC ONE X build prop in evo 3d?
Since the One X uses an S4 Processor (or Tegra 3) Some apps downloaded from the play store will not work properly and it will probably break 3D Games and others like Gameloft and EA games I can also imagine Apps will look funky since the One X is a 720p display and apps are probably formatted for its size
a quadrant score of 5000+ would be amazing
You can't just change hardware using the build.prop. I don't think that quadrant score is physically possible with the Evo V's processor. Nothing can change that. Its like asking if you can increase the size of the screen with some text in a file. It just can't be done.
im trying to break into the 4400 score for quadrant. the highest i've gotten is 4374 so far, so im not that far away from it.
here is my score.
if ur running MeanRom you can use AnthraX 2.8 and it will break into 4300+ quadrant score. i did this with MeanRom 2.4 and 2.5
oh snap...:D this is with meanRom and i've had faster, right below 8000.
lol, its not bullshit. look... see where it says HTC Evo V, thats my score... :D
