R RB26DETT Lurker Jul 30, 2011 #1 Hi Guys, Every time I try log in to my Facebook with my HTC it says 'Invalid username or password' Now they are both correct so what do I do to rectify the problem? Cheers.
J joshhedge Newbie Jul 30, 2011 #2 Double check? Are you inputting them with capitals? Otherwise you’ll have to use the web version by the sounds of it.
R RB26DETT Lurker Jul 30, 2011 #3 joshhedge said: Double check? Are you inputting them with capitals? Otherwise you Click to expand...
J joshhedge Newbie Jul 30, 2011 #4 I guess you should report the problem to the developer and use the mobile web version of Facebook until the issue has been resolved
