i have baked snack and htc sense keeps freezing it says force close htc sense and i do that but then it starts loading and it says force close or wait. how do i fix it.
oh, i got the same problem. force close, error in com.htc.launcher something .... i press it, it goes n comes back after 2 seconds and promtps to force close again , n again n again.
did you restore your launcher settings from another rom? i get the same with lp from time to time if i restore the wrong settings. do you have another launcher you can go to? If you can get to it, go to apps manage apps and find htc.sense and clear data and you will be fine
