Hey i was woundering if theres any HTC roms that are compatible for this phone im new to rooting and android so i dont know if you need special roms or what,
root acheived about a week ago.. they are working on a recovery now... once the recovery is complete.. im sure there will be alot of people working on porting voer a rom for it.. but its gonna be a while
recovery is anotjher part of the phone.. u have to power off the phone and then hold a key combination to boot into it. once in recovery you can make a backup, basically an image of your phones system files and everything on it.. and if anything happens you can restore it back to when that backup was made. recovery also allows you to do things like flash custom roms, kernels, a2sd scripts, etc. all phones have some kind of recovery on them.. most phones stock recovery will just put your phone back to the way it was when you bought it, but once you have a custom recovery installed, the door is open to mod your phone the way you like it.
