Help Htc sense ui error- help
TF1984
Friend of mine has incredible, he just started receiving triple text alerts and we cannot figure out how to fix it.
Handcent gives notification curtain alert.
Stock messaging app does same.
Each of these is normal and w know how to disable.
But the problem is the third notification. We think its the stock Android message app, beneath sense. It is also giving notification on every text. What's more, if this notification is clicked, nothing happens.
Any ideas? Problem seems to have. started after using launcherpro, have already tried removing it, preferences clear defaults and preferences restart launcherpro.
Still happening, any help out there?
Have you tried shutting all notifications off then only turning on either the stock or the Handcent notification. I had a similar issue and that solved it for me. Good luck
