J
jfs1969
Guest
Hi,
I have a been using HTC Sync 2.0.33 for a while, syncing with MS Outlook without problems. I upgraded to 3.0 and had teh following problems:
1. Lots of duplicates in Outlook Calendar (HTC support say they are aware of this issue), and
2. You can't choose which Outlook Contacts folder to sync with so can't only sync with non-work contacts say. (HTC support didn't seem to think this was a problem but why remove useful functionality in a supposed upgrade?)
Anyway, I want to go back to 2.0.33 but can't find the install file anywhere on the web. HTC support won't send it to me either!
Can anyone help?
Justin
Can anyone help?
Justin
