Hi
Recently I noticed my mouse icon was flickering from IDEAL to BUSY every 5 - 6 seconds even if I didn’t put system to do anything.
It took quite many hours to find out what was the reason, it really put me off thinking that my system is infected with Adware - Malware- Spyware or anything like that... checked every other program, including all possible malware, spyware programs but couldn’t find anything suspicious...
Finally I spotted that it was HTC Sync which was causing the mouse to flicker from ideal to busy status.. just to confirm that I removed the HTC Sync, and mouse icon remain steady - ideal.... no problems now... But no HTC Sync on system as well...
Tried checking solution everywhere.. couldn’t find it anywhere...
I am sure and very much positive that this problem (bug with HTC Sync) does exists but may be it was not spotted by anyone... or may be only exists with some specific model or OSs...
I tested this with Win-7, and also with XP-SP2 as well (fresh installed)... the problem does exists...
The only one thread I found somewhere was this -
http://android.modaco.com/content/htc-hero-hero-modaco-com/293112/htc-sync-2-0-4-problem-on-xp-sp3/
But no proper solutions or much of any confirmation...
Can anyone shed some light on this if had seen this issue a bit closely...
Thanks
p.s. - forgot to mention, I did try both the versions - 2.0.4 & 2.0.18
Thanks
I have no clue why it's like that - if the "pc suite"-type package just happens to get very lowest priority on most mobile phones manufacturers' lists or what.
