Help HTC Sync for Desire problem.
D
Deleted User
Guest
I have HTC Sync 3.0.5422 and have been having a problem with it, it's probably been posted before but i've looked hard and have found no answers, anyway when i open it up with my phone connected the "People" and "Calendar" sections are greyed out and i am unable to turn them on, have tried uninstalling and reinstalling the program, but still nothing..
Same issue. Same as above.
Why is it that when ever I try and do this kind of thing I run into problems like this. Got to love technology.
Do you have the appropriate option (Sync) set in your Desire? With the cable connected press menu > notifications.
Same problem here. Version 2 worked fine. All I did was install v3 on my PC. Phone is set to sync. It communicates wit the app but it specifically will not sync calendar or people. ver 2 still works fine. Back to ver 2.
Better is the enemy of good.
:mad: I've spent hours on this problem !! Called the help centre in the United Kingdom and nobody has a clue !!
It's as the threads reads load Sync 3.0.5422 and you can't sync your Outlook diary & contacts - Load 2.0 Sync software and it works but then you can't upload music, picture and other files so easily.
Wow !!:rolleyes: my Nokia software ( 3 years old) does all this and in bluetooth - Seems like HTC want you to use a USB connection everytime you wanna sync :mad::mad::mad::mad:
I removed HTC Sync because of the endless problems i had with it. MyPhoneExplorer works fine for sycning contacts and works on multiple PCs.
