HTC Weather Widget Location
STL 350Z
So I just got my Eris yesterday and the weather location keeps displaying (II) and not the city I am in. It will display on occasion but then it will go back to (II) My GPS is and on so is my Location also it's set to update every hour. I don't get it but it's starting to annoying me as my friends works perfect on his Eris. :confused:
Have you tried *22899 then "send" on the dialer to update/program the preferred roaming list (PRL)? You may want to try looking in your settings go to Location, make sure you have "use wireless networks" checked.
