Help HTC Wildfire - HELP!!
Amandie82
Hi Everyone, i have a wildfire and its telling me i am low on storage and i need to delete files.. i have deleted all my messages, i am no longer able to receive or send messages either.. what do i do??? (sorry if this is a silly question, i am a little backwards with technology :)
You need to also delete some programs you have installed.
The wildfire was made with not too much memory.
Jeff
yup thats all to do with your apps you have installed me thinks, menu, settings, sd and phone storage,check available space on internal phone storage, if you are under about 17mb you will get the low on storage warning
menu,settings,applications,manage applications, ( choose the app you want deleted) then hit uninstall.
when 2.2 comes you will be able to have more apps as some can be moved to the sd card
Hi, I have the same problem with very low memory. Can anybody please tell me, would using a duo pro memory stick work? If it would, where would it go on the phone? :rolleyes:
no, unless you have a custom rom with froyo 2.2( like wildpuzzle) apps cannot be shifted from internal memory, and the wildfire uses a micro sd card which is bottom left when looking at back of phone without cover
