Spaminator92
Hello all,
all of the sudden my Wildfire started acting up today.. I was texting with someone when all of the sudden my screen wouldn't turn on anymore. The notification led for a new message kept flashing. When I hit the power button to turn the screen on only the bottom 4 buttons would light up, so I'm guessing the phone was still reacting.
After that I tried for hours to get in the boot meny by holding volume down and then Power (not holding power). I managed a few times, but several other times the screen would briefly flash white and then I'd have to take the battery out again.
When I do get in the recovery menu, I can't select any of the options. Scrolling through the options with volume up/down simply doesn't do anything, the marker remains stuck on 'Fastboot'.
I really need help guys, the phone is only about 4months old, and it will be a real hard task to get it back to the manufacturer (online retailer)
it sounds pretty f#$%ed if you can't get into hboot, i know you can use trackball to navigate menu when in clockworkmod but not in hboot.
