HTC Wildfire S FAQ's
Status
Not open for further replies.
D-U-R-X
turbo drinker
This is a work in progress and, as such, if you feel that there is anything that needs adding, please PM a guide or start a thread in Private Chat With Staff with your suggestions.
Many thanks :)
1. General Android phone FAQ's?
2. How can I improve my battery life?
3. Are there any Wildfire S Tips & Tricks?
4. What are the known problems with the Wildfire S?
5. Forum related questions.
6. What is root?/What does being rooted mean?
7. How can I fix/replace my screen?
Q: General Android phone FAQ's?
A: Here is a thread on general Android Phone FAQ's
Q: How can I improve my battery life?
A: You should check out this thread: Battery life on this phone. You do not have to follow the tips offered, but they should help. Smartphones operate on a sort of spectrum... on one end you could put battery life, on the other end all those options like wifi/3g/sync (among other things). If you want great battery life you can't have those on all the time. If you want those on all the time, you won't get great battery life. It is best to find the compromise that works best for you and what you want most out of your phone.
Q: Are there any Wildfire S Tips & Tricks?
A: For any Wildfire S Tips, if you use the "filter by" and select "Tips" in the sub-forum, you will get many useful tips and tricks.
Q: What are some of the problems people have with their Wildfire S?
A:
For any Wildfire S Tips, if you use the "filter by" and select "Support" in the sub-forum, you will get info on any problems and their solutions.
Q: How can I fix/replace my screen?
A: This thread has step by step instructions: How to repair HTC Wildfire S screen
Status
