Help htc wildfire s internal memory low, memory card too small
htc wildfire s internal memory low & only 2GB memory card. I want to know if I can take a 4GB memory card out of an old phone & put it in the Htc Wildfire. please help I know that someone out there will knbow the answer PLEASE!!!!!:)
You can certainly use your 4GB card, providing it's the correct type of MicroSD card.
Backup all the contents of your existing SD card to your pc. Format the new 4GB card as FAT32, then copy all the contents of the backup you did to the new card.
