Turn off unimportant apps, that use power. I assume you have wifi, bluetooth, satellite, sync, and your brightness set all the way up. The little toolbar on your main screen. Unclick everything, and set your brightness to the lowest possible setting.
I get like 15 hours on a full battery charge. Not a lot, in comparison to my old samsung freeform, but better than nothing, considering it is an android... Androids use more power, due to a larger screen, and apps running full time.
I am running everything off, unless I am using it for some reason. I am also pretty sure, if you rooted your phone, and were able to get an app to set your CPU settings, that you could set it to run minimal, when not in use.
I suggest you get a portable battery charging station, and keep your USB cord with you, for on the run charging!
