my huawei ascend connects to blue tooth but wont let me connect with anybody [i dont know if im saying that right]. any suggestions?
What are you trying to connect to? Have you used Bluetooth before?
I've only used it a few times to connect to other devices to transfer files but here is what I know.
You have to turn on bluetooth. Menu key> Settings> Wireless & Networks> Bluetooth. Then click on Bluetooth settings.
Discoverable default is hidden. You can select Discoverable for 120 or Always discoverable. One of the devices has to be discoverable.
If the other device is already discoverable you can use the Menu Key then select Scan for Device.
Select the device you are trying to connect with. It will ask you for the Pin code (I think that's what it's called). Default is usually 0000 (ours has this one) or 1234. I don't know about headsets because I've never used one but if the code is different it should tell you in it's owners manual.
For another phone (or device) you will have to put codes in both sides.
Then it will ask you if the device is Trusted or not. Select yes.
It should give you a connected and/or paired status.
If you are trying to transfer files, go to the file and select share or move (depending on the device) and you will have a bluetooth option, which will the give you a list of bluetooth devices. Select the one you want and it should send the file.
I hope this helps.
what if nothing shows up after you scan?
