Root Huawei Ascend Phone Help
Okay so I tried to root my phone yesterday. I have the Huawei Ascend from Metro PCS. I was following the instructions from tokenpoke (a user on here). I accidentally deleted both of my keyboards. Now I cannot do anything that involves me typing. To make matters worse I tried to do a master reset hoping that the keyboard would just be back. Nope! That was an epic fail because now I cant even log in my google account because I can't type. If anyone can do anything or help me let me know asap thank you.
Okay on the computer go to google, and search Better Keyboard 8 apk (Its free in the market but since you cant type you'll have to do it this way)
Once you have found the apk file, download it and connect USB from your phone to the pc (so far this doesn't include anything with typing)
So then move it to your folder (A folder you can name "Apps") move it there.
After that is done disconnect your phone from the PC and open up file manager, and look for the folder you just made/or just put in the file.
Once you have found the folder "Apps" (or watever) open it up (just click it) and there should be only one file there, so click it and then after you clicked it,there should me a screen where it says if you would want to cancel or install. Press install, and wait a minute and then once it is all done, go to the homescreen and press menu and go to settings, and scroll all the way down, till you see "Language & Keyboard" go there and there should be keyboard 8 installed.
Now if you don't want keyboard 8, you can download any other keyboard and do the same process
2 options.
1. http://rapidshare.com/files/404268609/HTC_keyboard.apk and install it. or browse the market from your pc: https://market.android.com/search?q=keyboard&c=apps&start=48&num=24
2. revert back to stock...reverting back to stock, ok power down the phone and download and extract this to your desktop MetroStockRecovery-SCRIPTS.zip after you done that press and hold vol down, end key and tap power, your phone should be on the white huawei screen and it should stay there, now open the folder that you extracted and run both of these file, first run fastboot-windows you will see a black box come and leave quick, next run metroPCSStock-windows.bat than another black box will pop up and it will do its thing, once it finishes the phone will automatic reboot itself.
