Help Huawei Ascend Promblem
Delia060810
I have a Huawei Ascend....... What does it mean if my phone screen is black and the bottom buttons just keep blinking when you turn it on and have it on the charger. When its off the charger it stops blinking and its all just off. Could it be the battery or something else :confused:
I noticed that if you have the battery out of the phone, and hold the power button on while plugging in the usb, it will flash the bottom buttons until i release the power button...
So i would check to see the battery and phone contacts are clean, and it might possibly be a bad battery... or possibly a "stuck" power button?
Hey thanks for the advice. Thankfully it wasn't the charger but it needed a hard reset. I put it below so incase you know or hear anyone else having similar problems please lat them know a hard reset may be what the phone needs o(^.^)o
How to reset the Huawei Ascend using the buttons:
First remove battery for a few minutes and then put it back in.
Then at the same time hold the following:
volume up, call button and power button (hold until it vibrates)
When it asks for permissions select:
select wipe data/ factory to reset
Thanks for sharing the solution.
