Scarsketch
Huawei Ascend Y H866C POOTED!!!
If you have been lurking the posts on google for a root for the phone, you are just like me, so i decided to learn some things. I contacted GiantPune and we worked together applying this root: http://www.sendspace.com/file/k9b3ks
download poot, install it let it download and install ministro,
start poot,it will then start ministro
Ministro will create some libraries,thats ok.
Poot will then start, make sure to press the poot button and then it will give you some code
At the end of the code somewhere in there it should say sucessfully found and wrote su.
press the built in rootcheck to see if you are rooted
restart the phone go to the playstore and download Superuser.
You are now fully rooted!
All the thanks goes out to GiantPune for his awesome and funny creation.
Let me know if this works and if I helped you,please press the thank you button!
thank you so very much
Thank you for such detail Metroid Scarsketch in your posting, It made an overwhelming process grasp-able!
