Huawei G510-0200 firmware update 2/2 process failed.
My Phone is Huawei G510-0200. I installed successfully CM11 ROM to my device (Rooted by Mobogenie, Bootloader unlocked by DC Unlocker) by using TWRP recovery.
Now i want to go back normal Huawei stock rom...
I downloaded Huawei Firmware from their web site (sorry i'm a new memebr, can't post the link)
this is the name of downloaded zip....
G510firmware(G510-0200,Android 4.1,Emtion UI,V100R001C00B200,General Version).zip\G510firmware(G510-0200,Android 4.1,Emtion UI,V100R001C00B200,General Version) - ZIP archive, unpacked size 1,157,577,177 bytes
I formatted my SD card and copied "dload" folder to SD root...
After that i went to TWRP recovery and did cache clear factory reset etc....
After that i tried to install firmware by pressing volume up + volume down and power....but installing(2/2) failed.....:( what is the problem? pls help me... Thanks All!
Hi samirusanjeewa,
Downloaded G510-0200 B200 from Huawei G510, which also extracted to 1.07 GB (1,157,577,177 bytes), is that where you got it from?
Following the instructions, flash each UPDATE.APP in order:
1. transfer > put the UPDATE.APP file in a new folder "sdcard\dload" and run forced upgrade (vol up + down)
2. dload (main) > overwrite UPDATE.APP "sdcard\dload", run forced upgrade again
3. vendor > overwrite UPDATE.APP "sdcard\dload" and run forced upgrade for a final time
* the UPDATE.APP needs to be copied from each folder to sdcard\dload\
* phone should reboot after each forced upgrade
I originally only flashed the dload update.app, and while it worked, it was missing a few things.
Found the B200 to be good. I used Nova Launcher with all animations disabled and scroll speed set to "Faster than light" for scrolling homescreen and app drawer. Makes it faster, until you open an app and snap back to reality.
Regards,
Andrew
I was wondering what I was doing wrong....but luckily found this post and restored the stock firmware which I messed up.
Again man thanks A LOT :)
Hi samirusanjeewa,
Regards,
Andrew
hi,
can you give me the link to donlowd a firmwire with transfer and vendor file for à g510-0200 plz?
