Help huawei m860 stuck on android screen
please help
Ok first and foremost what did you do or not do to it? Did you root? If so what did you use to root with?
We need to know, did you just do a power off, and then try to power it back on? Did you flash anything to the phone.
This is all information we are going to need to know to try to help you.
If all else fails follow the instructions on doing a factory reset.
