Huawei MediaPad M5, which terminal?
just do a search on your device in the play store. all searches results will show only what is compatible for your device. i do not have your phone so i can't comment what will or will not work.
Thanks for your reply, actually my question was criptically asking: please let me have some similar tools, good, and I will check, but from the store I did not see any, maybe I have to search for another keyword. If you have some suggestions of an equivalent tool please let me know.
Thanks
That app is for a very old version of Android.
You may try contacting the developer to see if there are any plans to update the app.
It is quite possible that Android has moved ahead and beyond the capabilities of such an app.
