vivekreddyp
Member
Hi
i want to install the ics upgrade for huawei
as you can see the earlier thread started by me. I already attempted the upgrade and has been succesful to some extent, but i ant to know
the files i have downloaded are from huawei web site
do we require rrot for it
if no then can you provide me any link for adb drivers for u8800 pro
does adb driver plany any role for this software upgrading process or it doesnot play any role
will i place any problem after updating because last time i couldn't make a call after update process(that to after some hours)
i really need upgradation because i am bored with the 2.3.5
I hope it all goes smoothly for you.
Neil.
