you mean sim unlock or bootloader unlock, I'm guessing you flashed the stock rom and that did not help, so what app did you try to unlock it with.
the deodexed stock rom cannot be flashed in fastboot, you need cwm to install it
what you can do is try to install this one since I'm guessing you never installed cwm using the force method(using stock recovery to flash it)
http://androidforums.com/vitria-all-things-root/838279-rom-official-b132-stock.html
or you can install cwm in fastboot then install the deodexed zip(recovery.img must be flashed in fastboot)
Dev-Host - recovery.img - The Ultimate Free File Hosting / File Sharing Service
