vshand wrote:
"Finally make Hulu works on SC 2.1 voodoo. Following listed steps.
1) Extract old version flash 10.1 installer apk from the eb01 stock and install it.
2) Extract update script file from the zip file, flash_hulu_installer_v3.signed.
3) Open the update script file and following the steps in the file to cleanup and extract system dir and data dir in the zip file to /system and /data.
4) Reboot and Hulu is back."
So, to clarify, what I think he is meaning is
1) Extract or unzip the stock EB01 froyo and go to "stock_eb01 folder\system\app\" and copy "install_flash_player.apk" and install to your phone
2) Extract/unzip flash_hulu_installer_v3.signed.zip file, and open the folder. Go to flash_hulu_installer_v3.signed\META-INF\com\google\android\ and open "updater-script" with notepad.
3)now your looking at:
mount("BML", "system", "/system");
mount("BML", "data", "/data");
# ---- start making changes here ----
show_progress(0.100000, 10);
ui_print("Remove old files...");
delete_recursive("/data/data/com.adobe.flashplayer");
delete_recursive("/data/data/com.android.browser/app_plugins/com.adobe.flashplayer/");
delete("/data/app/com.adobe.flashplayer-1.apk");
delete("/data/app/com.adobe.flashplayer.apk");
delete("/system/app/install_flash_player.apk");
delete("/data/dalvik-cache/data@app@com.adobe.flashplayer.apk@classes.dex");
delete("/data/dalvik-cache/data@app@com.adobe.flashplayer-1.apk@classes.dex");
ui_print("Pushing new version of Flash...");
show_progress(0.100000, 5);
package_extract_dir("system", "/system");
package_extract_dir("data", "/data");
show_progress(1.000000, 0);
ui_print("Set permissions...");
show_progress(0.100000,5);
set_perm(0, 0, 0755, "/system");
set_perm_recursive(0, 0, 0755, 0644, "/system/app");
set_perm_recursive(0, 0, 0755, 0644, "/system/lib");
set_perm(1000, 1000, 0755, "/data");
set_perm_recursive(1000, 1000, 0755, 0644, "/data/app");
unmount("/system");
unmount("/data");
And now I have no idea what he means by "Open the update script file and following the steps in the file to cleanup and extract system dir and data dir in the zip file to /system and /data," But as soon as I do, i'm sure you just make the changes and save the file and voila, everything is fixed.
Or, does he simply mean to look at where the script would normally put the files it updates for flash, and go there on your phone and delete it...? ie, "cleanup"? I dunno, i'm going to play around with it and see if I can decipher this enigma...lol.
***Update: I'm guessing what he meant was to follow what the script would normally do and "remove the old files" at:
And then install the new flash files into these directories, "Pushing new version of Flash..."
So, I really think all that is going on here is he's wiping out the updated version of flash that is already installed on your phone via the new rom you installed (ie, super clean 2.2) and reinstalling the old/untouched version of Flash manually, which is what the flash_hulu_installer_v3.signed.zip does in CWM in non voodoo versions, and would have done if the CWM for Voodoo would work with it.
That makes a lot of sense, but to me, the way Vshand wrote it was extremely confusing. So i'm going to see if I can get this to work and if so, I'll come back and write a complete and simplified step by step for getting hulu working with voodoo versions of superclean.
So if anyone knows what he means, please, by all means, let me/us know and get me my goddamn HULU BACK!!!!!
Thanks in advance!
unmount("/system");
unmount("/data");
Thanks in advance!
