Don't, unless you have the stock rom loaded. It will all go horribly wrong!
Did the phone work correctly before you rooted it?
I would start again. Wipe data/cache, flash your rom, flash the correct gapps, login to google, make sure it works, then restore your backup.
If it still doesn't work, restore the stock rom (assuming you made a backup) and see if you get data. If not, at that point, call Virgin. (With the stock rom loaded).
Alright guys and girls not sure if girls are here lol anyways, I got my phone fixed. It was simply just the bad signal. I went to the bathroom and then played with my phone..let me give a try and see it might work and bam all works fine now. Wierd huh!? lol
Anyway; Mods you can close this thread if you'd like to or save it for newbies and they can read.
