Help I cant install small apss using HTC sync. help plsssss
polroke
whenever i install amall apps in htc sync it always says. "Installation failure. Please check if the file and ensure that there is sufficient space of the mobile for installation."
Welcome to the forums, polroke.
I'm thinking that you may only need to clear the caches of various apps in your device to allow for more room for new apps. I'm also wondering, though, if you've downloaded and installed a lot of apps and widgets on your Explorer and now it is in need of some trimming out (uninstalling) of some of those apps/widgets.
The Explorer has only half of a Gigabyte of memory, although it does support 32 Gigabyte sd memory cards. What size sd card do you have?
