Root i cant receive calls on liquid smooth
lilcourv
I can't receive calls or voicemail..I haven't tried MMS yet so I don't know about that,I haven't seen anyone else having this issue..I've done a full wipe and I'm s-off on jbear 1.50 and using 4ext,I'm on virgin mobile..if anyone could help I would appreciate it
No issues here...same setup
I did have to install textra and add the virgin apn for MMS
I would suggest flashing something like harmonia and update prl and profile
Then make sure calls out and in work, MMS .... Etc
Then do a fresh install of liquid
Ya I was looking into the textra..just haven't had a chance, I have done the Joe blow hacks awhile back..thanks for the reply ill try it out
