I was using my mass storage just fine via USB and I accidentally unplugged it without ejecting first and now when I try to use it i can't move files back and forth off/on my sd card.
Try unmounting then mounting the Internal SD card.
Normally if you unplug the USB before you unmount, it doesn't finish the scanning process on your phone. It's till trying to read the contents as if it's still plugged into your computer as an external drive.
