Root I-carus: FORCE CLOSE problems
im using cricket, message is, " the process com.google.process.gapps has stopped unexpectedly. please try again. it happens when im in "market" and happend when i did my first boot. happens alot really....
gmail error, I believe... uncheck autosync and recheck it and manually sync all. if that fails... remove battery while phone is on and wait 10 sec and put battery back in and boot up the phone and try again.
neither of them worked. i dont know what is wrong, but i cant download anything at all..
try this take out your sd card and reboot the phone without the card in it and try to go to market and download something and see if it works. leave card out...on another thread i seen this has happen to a few others...but what i had did when my market was messed up i uninstall the update and it work, and on my wife phone, hers was aciddently deleted by me so i just reflash everything and no more problems/force closing.
still popping the force close. and without the sdcard,click market it says could not launch the requested activity.... what the hell is going on? im really tired of this, imabout to unroot and stock flash
having issues with force close, just flashed with I-carus... any help?
all these bugs were fixed in Icarus 1.1. I think you should try it, it works wonders on my ascend but if you are with metro the mms doesn't work on Icarus 1.1. if you're with cricket then you're good to go XD
It is under the Icarus 1.1 thread of how to fix the MMS. It's quite a simple fix and worked for me. I'm having LESS force closing that I was with the stock.
