Welcome to Android Forums.
Most likely you didn't delete the browser. You can't delete system apps without rooting your phone. What you probably did was remove the icon from the home screen, or launch bar.
Open your app drawer (the icon that looks like four squares, usually at the bottom of your home screen) and locate the browser. Long-press the icon (touch and hold for 2+ seconds) it should switch back to the home screen with the icon still under your finger. Drag it anywhere you'd like to to be.
