xTXRxFrosty
Member
I just accidently formatted my /system in cwm... couldn't stop it.
Did I F-up majorly?
Did I F-up majorly?
Did I F-up majorly?
If you are still in CWM just flash a ROM
Seeing as how Android is open... don't you think it will super easy to download/install a ridiculous amount of games to your phone? Think about how many simple flash games are out there.
Will android users immediately have a huge pool of mobile games to choose from or do these developers have to design games specifically for Android?
Pull the battery.
Replace.
Press both of the volume buttons and hold the power for a few seconds, maybe 1 or 2
Tap the power button a few times.
Should get you to recovery.
Pull the battery.
Replace.
Do I keep holding the volume keys? I'm not getting recovery...
Select power to reset then should boot to recovery then:If you are still in CWM just flash a ROM
Do this now-put a ROM on your sd via computer^^^
Okay, so I did get this... Permanently Erase User Data & Reset Settings? Press Power key to confirm. and any other key to cancel
No Recovery yet though lol
Should I ignore this and keep trying for recovery?
oh btw... nows a good time to mention, there is probably no rom there anymore, I just formatted everything.
Should I still pretty much assume I'm screwed?
Wait... just to be certain, because you quoted Fuzzy, you're saying to push power on that screen I mentioned above?
Okay, so I'm in recovery, but now I'm confused... it gives me an error when mounting... I dont have an actual SD card... just the internal, should I put my wifes SD card in?
Okay, so I'm putting a ROM on the SD card now... stupid phone, I had to pull the battery to put it in so I gotta get back to recovery now lol
That's fine-if it doesn't reboot to recovery just do the reset again. Then just flash the ROM you put on the SD -No need to wipe anything as your os is gone anyway:thumbup:
Anytime dude. I'm never the first one to answer. Usually Gbiggie, Shiny, Mex or Fuzzy or any of the regulars beat me to it![]()
Good deal!
Fuzzy and Johnny Crappleseed pointed you in the right direction
You realize you have to unroot your phone for a week as punishment(it's like an unwritten rule)
NO NOT REALLY
