I followed through, I returned my Captivate.
BobPaul
Over the GPS and to a lessor extent the 4 buttons being too hard to use.
Good luck to everyone with the GPS optimizations that are supposed to be delivered in Sept.
I'm thinking Streak! Naw, that is stuck with pre-2.x Android. Hmmmm.....
If you decide to goto streak or any other AT&T android phone would be a step down from captivate spec wise. You could just return captivate and wait to see what samsung does to fix lag and gps ?
What's funny is the GPS for me initially was really poor. Now it is more accurate than my Magellan. It's been the last week that it fixed, but even before that, it was good enough where I was using it to get around Kaua'i while on vacation.
