Root i formatted boot system and data...
welbinator
Like a moron, I assumed all android devices are the same, and I formatted my system, boot and data in the process of flashing a ROM. Now, my nook is stuck at the black screen with the n symbol in the middle and the words "contains reader mobile technology by adobe systems incorporated" at the bottom. please tell me I didn't just break this thing...
I never format boot. Don't see why it would be needed.
I assume you formatted and then flashed your rom? I would think that would work, but it sounds like it didn't.
Exactly what rom did you flash? Did you also flash an OC kernel?
Unless it's a compatible rom/kernel, that could be your problem.
