potterdood
Ok, so here are a few of the things that I've noticed that aren't exactly as they should be, and that I'm accustomed to on Android. I did come from a Razr Maxx so correct me if these options shouldn't be available for touch wiz in the first place. 1. I play the world series of poker application alot, and in the past have always synced it with my fbook, and now when I try that it just kicks me out of the application. There are multiple applications I'm having this issue with as well, can't remember them w/o going back thru the apps and trying again tho. 2. I have kik and when I go to send a pic on there, I take the pic and then choose save, it says saved but then doesn't go to my gallery, nor does it show up in the chat box to send. 3. There is no power option widget on the phone, not sure if I'm missing it or if theres a similar option, the only thing I've noticed is there is something like it in the drop down notification menu, but the main concern of me wanting it is for the brightness control right there on the home screen. 4. When typing in a text message, or any message for instance. There use to be arrows above the keyboard incase you needed to move the cursor around without having to click and then drag the blue icon to the right spot, made it easier imo to get to where you needed to correct your typing mistake. 5. Swype is different, when I want to add a word to the saved dictionary, and I type the word then click it on the part where swype populates the same word or guesses of what you meant, it never confirms that it's saving into the dictionary. Anyone else noticed these things?
