I have no 3 or 4G
GNS1310
I was out at the NYS Fair today and went to post on Facebook, noticed I couldn't do a thing. No 3G or 4G...couldn't use Twitter, FB, internet, nothing.
I'm on WiFi at home...don't use my phone in the car or at work...just noticed today that I had no service. Bill was paid last week lol, on time, as always...
I turned it off then back on to try to reset it, but nada.
Any ideas?
Sounds like you've tried everything so I'm going to assume you did the obvious things like checking the phone isn't in Airplane mode etc ..
I think your only option is to send the phone in for a repair :(
Hopefully it's still under warranty ..
No... This is either hardware (phone or SIM), or carrier. I would contact Verizon technical support and troubleshoot with them.
Do voice and text calls work?
Also, check the back cover, it is the antenna, if it is off slightly or the contacts are not connecting for some reason, the issues you describe are possible.
You may have accidentally turned mobile data off too. Check that. Also, there are apps that will reset the radios in your phone. I use Open Signal.
