Help I killed my epic help
I have turned my epic 4g into a brick I flashed a different recovery that came with one of the newer updates to the clockworkmod recovery odin won't find it and I can't find away to get the unbrick tool from Europe the phone won't even charge there really are no ruining systems at all I'm at a loss at what to do
Can you get to the boot loader at all? Power off>qwerty open>press & hold the #1keyand power both at the same time until it boots, just in case you didnt know.
Yeah i know quite a bit about most android versions I'm running cyanogenmod7 android 2.3 smooth but nothing will find it no program or computer will recognize what it is
so no odin? i have a copy of the samsung updater tool that i could link you. always more than one way to skin a cat as they say;)
That file just fried my computer when it tried to install from the phone great worse of than i was now
how did it just fry your computer? All it is an intaller for the epic that was from samsung during the eb13 launch. All its suppose to do is install drivers and then flash stock os(eb13) on your phone.
The phone was installing something I brought the computer back but I think the phone is corrupt or something but no that file didn't do it but I don't think its fixable I'm thinking the programming is overloaded it doesn't charge even
Well i feel a bit better. See abve post and edit. Try pulling the battery out overnight. Also see this thread on xda, may or may not help - http://forum.xda-developers.com/showthread.php?t=1042746
