Root I lost my keyboard!!!! Help
keving
Member
I rooted my daughters NC today, and installed Launched Pro. All was fine. Now I have no keyboard!
Now when I go to a search site, I do not have a keyboard so I cant type anything. Pretty much anywhere where I would need to type in info, I have no keyboard.
I removed LP and tried Launch Pro EX. Still no keyboard.
When I go to settings on the stock home screen, and go to keyboard, i get sent back tot he home screen.
Any ideas on how to fix this? How did I loose it to start with?
Try doing a long press on a text field, and you should get a popup box that lets you choose which keyboard you want to use. After that, the keyboard should come up like it used to. If that doesn't work I don't know what to tell you :(
