Already mentioned this in the Hints and Tips thread but didn't get a response.
Anyway I used the ''force apps to sd'' thingy, where you change the install location by connecting your phone to your PC and use commandprompt. You know: Lorin Bute - Home - How to force apps to move to the SD card onFroyo. Everything worked great until recently when the phone became unable to install many apps when microsd was chosen as the install location and some apps still wont install even with the setting set back to default. I can still force already installed apps to move to sd.
One other odd thing is that I tried to install a GPS app and the installation failed (with the default install location). Then I quit almost all running processes using the built in process manager and then the install worked. After a reboot I tried to replicate my actions but no matter what I did I could no longer install the same app.
My phone's inability to install some apps appears to be completely random.
What's worse is that I installed froyo around the same time so maybe it has a part to play in my problem.
