Help i need a custom rom
vinuvpmv
Can anyone help me find a stable custom rom arnova 10d g3 tablet
it have 1 gb ram 4 gb rom 1.2ghz cortex a9 processor. inbuilt rom is unstable ...so much problem please help me
Hi, I didn't really think I would find anything for you, kind of a rare device. I found some ROM's for the 10d g3. Unfortunately everything I found is over three years old. The only ROM's are Jelly Bean which is becoming quite outdated. I found some experimental CM ROM's , but they are not considered stable by any means.
It means you guys cant help me with a new rom.my inbuilt rom is buggy.wifi drop google play etc...please help me...i am also getting the same as you...but you are developers you know better than me...plz help me...i beg you..ASAP
Actually, we are not all developers. A developer usually owns a device to develop. So that is what you need to do, find a developer that has that device, good luck. The device is obsolete. Development has stopped.
I pointed you towards the best solution I could come up with. If you'll notice there haven't been a lot of other responses. That is because what you ask for doesn't exist.
A lot of other forums would have started off with this:
http://forum.xda-developers.com/showthread.php?t=633246
If you want a custom ROM.....start building it.
how i build custom rom i am a noob not a computer nerd...and the link it confuses my brain...i couldnt understand a thing
atleast do me a favour find me any forum which could build me a custom rom from the ashes of original rom and the specs of the device
If you do not understand Android development, then you probably do not want to try building a custom ROM. Everything in it has to control all aspects of the tablet perfectly: one wrong character in the code for one thing may throw something else out. If you're not careful, you will end up with a badly bricked device. I would suggest getting a newer, more popular device instead. It would be a lot easier for you.
Hello--I just replied to your thread in our Introductions area :) [didn't see this until just now].
There is also the other side of the coin that I don't see mentioned above in the above (most excellent posts and advice you're already been given) is that you'd most likely need to be rooted, have a custom recovery installed, know how to take a Nandroid backup, and how how to wipe and flash/install a custom ROM.
If your not already familiar with those concepts, then having a custom ROM is putting the cart well before the horse--i.e., there are a lot of other things to consider, too.
i have a mobile redmi 1s and i have it rooted,custom recovery installed,flashed several times with several rom and atlast found a stable rom for it.I know how to flash...but the problem is i dont have rom for my tablet anywhere
i cant buy new one cause i baught this on a fair price like 2500 indian rupee... i think there is no popular brand which will give me a 10 inch screen and wifi...
all i wanted is a custom rom so i will be safer than the buggy rom inbuilt...
all i am asking for your help from developer side is that you people can build me from the original inbuilt rom availabe in the website http://arnovatech.com/support/updates_fwm.html?country=at&lang=de
and the spec...sorry if iam wrong...i dont know deep inside these things
thanks sir...i am not going to play with my device ...i have no money to afford new tab.but i just wanted to know if you guys can help me
I'm sorry: we're Android enthusiasts, but very few of us have development experience. And I am not confident that you will find a developer out there who will commit to the time and effort to develop a custom ROM for you. Good luck :)
one more doubt sir
from the source of original firmware and and the specs can developers create custom rom?
one more doubt sir
We have a ROM Development area, but it's sparsely populated...most ROM development discussions happen in the specific root areas for each device (and I'm guessing that we don't have an area for your device here at AF).
ROM devs can do amazing things even with just the stock ROM, but if the stock ROM is unstable (guessing that it's actually the kernel that's the unstable part of that you just have an old, underpowered device), that's not going to help you.
You're probably looking for a CM (CyanogenMod) type of custom ROM--but again, you'll have to find a dev or group of devs that are willing to develop that for your device. Chances are, though, if it's an older device and hasn't been done by now, it won't be :(.
I'm not a ROM dev, so I can't speak to exactly what is needed (I know things from having read for the last 7 years, but have not built a custom ROM myself).
I'm sorry that we could not help, but trust me you are not the first. Whenever I look at buying any new device, I check the development first. It is a common mistake to assume (thanks to the internet) that every Android device is able to be customized in such a way. I purchased a Google Nexus 7 (2013) just for this purpose alone! One of the best decisions I ever made. Remember, research then buy not Vice Versa.
If that confuses your brain and you can't find a forum that has development for your device, you are out of luck. Sorry. Consider buying a newer device. I have an Asus Memopad 8 tablet with no development but root. I know what you are going through. I bought it because of price not development so I gambled when I made that choice.
